Where can I find a new 4.8l short block?
Old Nov 11, 2012 | 09:46 PM
lycominghunter's Avatar
Default Where can I find a new 4.8l short block?
Evening,
Anyone know if there is any place where I could purchase a new 4.8l short block? Havent had much luck in finding one...THANKS
Old Nov 12, 2012 | 05:03 PM
DAMN, i know a 4.8 isnt a 6.0 lol, but no one knows where I could buy a short block? That or no one makes em HA
Old Nov 12, 2012 | 05:26 PM
Mangled03gmc's Avatar
Baltimore Whore
Why do you want or need a NEW one?
Old Nov 12, 2012 | 07:20 PM
Well, i guess its just kind of thing with me. I have always like to start with new parts whenever I do a build. Most of my experience is with motorcycles, and whenever I'd get a new one, I'd have the cylinder(s) plated and honed, get a new piston and rings and wrist pin. Problem is, that whenever I finally find the truck I'm looking for (00-06 rcsb) its most likely going to have over 100k miles and I want to turbo it. I want it to be reliable because it could be my DD for a year or two. I would like to keep it a 4.8 and don't think that boring it out and getting custom pistons will be that cost effective. Just dont think that turboing a 100k+ mile truck for 10-12 psi would be that reliable. Any options, opinions, and ideas would be greatly appreciated
Old Nov 12, 2012 | 11:05 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The only place you can get a NEW one would be a GM dealer or a GM supplier. Every thing else will be re manufactured or rebuilt.
Old Nov 12, 2012 | 11:10 PM
Baltimore Whore
You would be surprised what a ls engine looks like with that amount of miles on it. For the price you can get a used one form you can slap new rings in it, bearings. lifters, pump and timing chain. The cylinders usually have the cross hatching still in them. In the begg, I would have been a little skeptical about boosting a used engine, but seeing what they can take,I would have no issue putting it to it. Not to mention buying a NEW or low low mile take out other then on here you will pay a **** load of money.
Old Nov 13, 2012 | 07:19 PM
hmm good information Mangled and FastBrick. Thanks for the input. I guess I'll just rebuild a used one then. Would you only worry about changing the rings and not the pistons?
Old Nov 13, 2012 | 07:26 PM
TXSZ66AVLANCHE's Avatar
4.8 pistons are dirt cheap, if your going to change rings go ahead and replace the pistons.
Old Nov 13, 2012 | 07:52 PM
Baltimore Whore
If the pistons are in good shape, I see no reason not to use them again. Hell they have already been stressed, seasoned. Rings def yes, if you plan to boost it hard, it might be a good idea to open the ring gap a few thou over stock..True talk
Old Nov 13, 2012 | 09:26 PM
1FastBrick's Avatar
What he said. If there in good shape, run them. I always have the machine shop check them in relation to the bore. This way I can get the best fit in each bore.
If the pistons are ok, I would get New rings, New cam crank and rod bearings, New gaskets, New cam retainer plate, New oil pump, New barbell/oil diverter in the back of the block, New lifters and trays, and New rod bolts. Obviously if your going to this much trouble your probably going to put at least a mild cam in.
If the crank or rods need machining make sure you get the correct bearings for that.
Always have everything inspected FIRST before buying the replacement parts.
HTH
