where is the camshaft serial number??
Old Dec 27, 2012 | 07:00 AM
07blksilverado's Avatar
Default where is the camshaft serial number??
Do I have to remove the cam shaft to get the serial number so I can get the cam specs? I bought a 6.0 an wanna know what the cam specs are on it. It has a comp cam in it
Old Dec 27, 2012 | 08:26 AM
Gadgetized's Avatar
My comp cam has the numbers on the end facing the front. You could also measure this with a degree wheel and a dial indicator.
Old Dec 27, 2012 | 09:38 AM
Ok so I could jus remove the timing cover an the timing chain an get the serial number?
Old Dec 27, 2012 | 09:40 AM
03sierraslt's Avatar
You will have to remove the cam gear also.
Old Dec 27, 2012 | 12:05 PM
Ok thanks!
Old Dec 27, 2012 | 12:16 PM
If the rockers are still on just make sure the cam does not move at all and throw off the cam timing when you put the gear and chain back on. Better yet just line up the timing marks prior.
Old Dec 28, 2012 | 07:10 AM
Sounds good I preciate the help! I jus wanna make sure the cam card I have goes with the cam that's in the motor
thompson
Dec 27, 2017 06:48 AM
wickedRCSB
Oct 10, 2015 09:29 PM
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
sTNT971
Sep 26, 2015 04:22 PM
