whats a Healthy CAM more wild side DD..??
Old Sep 3, 2013 | 07:08 PM
sleeperlqx's Avatar
Default whats a Healthy CAM more wild side DD..??
Need some cam recomendations for my new setup:
6.0 lq9
Ls3 or l92 heads shaved .015 for a 11.1 compressiin ratio
Ls7 lifters
Cai and longtubes with full exhaust
Carb l92 intake single high rise but going to add injectors, rails, afpr. 90* elbow with 102mm tb
4l80e tranny with 3600 stall and 3.73 gears on 265/50/20
The truck Tahoe. Never tows and has a bunch of weight reduction. Daily driver, time to do a freshenup of top for more power.
So I need a pretty stout cam as I so like to play. And thus going l92 route I need power in mid and top side.
Old Sep 3, 2013 | 07:13 PM
DTHPROOF's Avatar
I run a stupid big-cam and I'm considering going smaller because it's my DD. It has good manners and pulls like a freight train but I think I can pick up a bit under the curve with a smaller cam. Mine is an Advanced Inductions custom grind. My advice, stay 232 or smaller buddy.
Old Sep 3, 2013 | 07:25 PM
dirt track racer 81's Avatar
Sell ya my 251/267 .623/.623 115+6.. You wanted wild lol..
Old Sep 3, 2013 | 07:35 PM
Blackpanther99's Avatar
Thats a donkey dick size cam right there for a truck
Old Sep 3, 2013 | 07:36 PM
As far as a cam goes id go custom grind while you are at it man
Old Sep 3, 2013 | 08:26 PM
TXsilverado's Avatar
LQ9 with shaved l92/ls3 heads will definately limit your cam size. especially when paired with the low LSA/ICL that single plane intakes seem to like. PTV clearance will be pretty tight with a good size cam.
Old Sep 3, 2013 | 09:14 PM
sleeperlqx's Avatar
Not thinkinking anything big by any means. But ridiculous mid to top comes to mind. I was more thinkin 228 range but I want to hear some input. Ill have to get 1 speced. But I need under curve power too I want it enjoyable
Old Sep 3, 2013 | 09:33 PM
skeet's Avatar
DTR's cam will never work unless you work the pistons lol
231/239 i found to be a perfect cam but with a different intake i was maxed out with this cam with .621 lift.. you really need to get a cam specked out for your setup, there's to much involved to play a guessing game!
stay in the 232/238 range if youre gonna spray a little juice
Old Sep 3, 2013 | 10:57 PM
oakley6575's Avatar
I have a 231/239 114+2 .600" lift cam sitting in my short block right now if you want to pick it up. I would run a 3200 stall converter with it at least.
Old Sep 4, 2013 | 02:06 AM
jmgak47's Avatar
So what does that make my 270/278 .70x/.70x 110+4? lol
