What pushrods lenght are you running with Ls7 lifters?
Old Oct 30, 2012 | 10:49 AM
Camin00's Avatar
Default What pushrods lenght are you running with Ls7 lifters?
I have been reading some people say they are .5 inches taller in the lifter.
It also says they are the stock replacement lifter.
When I do the cam swap I am reusing non milled heads and new stock .053 head gaskets
Can I keep my new 7.4 pushrods or will the be to much pre load on the lifters?
Old Oct 30, 2012 | 11:37 AM
TXSZ66AVLANCHE's Avatar
I believed the .050 taller bs also and ordered 7.450 push rods, they were to tall, ordered a push rod checker and 7.400 worked perfectly on .051 head gaskets.
Old Oct 30, 2012 | 11:58 AM
Ferocity02's Avatar
They are .050" taller, meaning you would want shorter pushrods for the same preload.
I used 7.350" pushrods for 0.075" preload, measured with a pushrod length checker, stock 706 heads and stock Felpro graphite gaskets.
Then I went down to 7.325" pushrods when I got 799 heads milled 0.022" with LS9 gaskets, same preload.
Old Oct 30, 2012 | 02:31 PM
Camin00's Avatar
What is the pre load range? .6-.9?
For got to mention 1.8 yella terra rockers are installed does this affect anything compared to stock rockers when measuring preload?
Old Oct 30, 2012 | 02:49 PM
Ferocity02's Avatar
Depends who you ask, but IMO, 0.050" - 0.100" is an acceptable range. I would go with a little more preload than less for a quieter valvetrain. Comp sells their pushrods in 0.025" increments so you can at least get into the upper half of that range. Do a search on tech too in the gen III internal engine section.
Old Oct 30, 2012 | 05:49 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
It depends on the motor in my opinion. We have seen some motors need a shorter push rod and some not. Its always best to use an adjustable push rod length checker and measure.
To the poster above who purchased longer push rods for a longer lifter, you should have got shorter push rods if anything. I bet it made a lot of noise if you started it.
Old Nov 4, 2012 | 07:04 AM
kush killer's Avatar
hmm ii was hoping i could use my 7.400's but now i think im gonna have to buy a length checker and see... ls7 lifter,862 heads ls9 gaskets....
Old Nov 4, 2012 | 09:11 AM
Preston129's Avatar
7.425" with LS9 gaskets on mine. Can't remember what I figured for preload but it was within spec.
Old Nov 4, 2012 | 03:39 PM
sand man's Avatar
running 7.425 will be going for 7.400 with new LS9 head gasket on my 408 build
Old Nov 5, 2012 | 07:21 AM
so ya think ill be good with my the 7.4's?
