What Length Rods?
Old Jan 11, 2015 | 05:23 PM
GM1697's Avatar
Default What Length Rods?
What length pushrods would I need with a 212/218 TSP Cam with .522/.529 on a 112LSA?
Going to be using the blue ls6 springs with stock heads.
Thanks
Old Jan 11, 2015 | 05:28 PM
dirt track racer 81's Avatar
7.4" unless tsp says it's on a smaller base circle
TheBeeblebrox's Avatar
Get a pushrod length checker tool. That way you can set the preload to what you want, and make sure everything is 100% correct.
Old Jan 11, 2015 | 06:44 PM
GM1697's Avatar
Thanks, Dirt Track.
Beeble,
I had checked out those length checker tools, but I was hoping to only have the truck apart for a day. But if it's the right way to do it then I may have to deal with having the truck down for a week.
Is there a certain preload amount that is considered optimal?
Old Jan 11, 2015 | 07:07 PM
If you can swing it buy a few sets at different lengths and just return what you don't use.
I'm running at .075" preload w/LS7 lifters, I think the recommended range is something like .050"-.080"? More preload tends to be on the quieter side (no sewing machine) from what I've read (mine is pretty quiet too).
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
