What else could break?
It is definitely A lifter clip! I have seen this many times on early Chevy engines and on one Ls1 that was severely over-revved due to missed shift. If the valve spring is broken or weak, this can happen.
Originally Posted by ZZebes
thats great that you found that but wheres the rest of it???
I found this on top of the #7 intake lifter after pulling the rocker arms and pushrods. With the lifter retainers you can't see much down the pushrod hole. I stuck a long screwdriver down each hole to hame sure the lifters were all seated. Then I stuck my pen magnet down each one to feel for a loose top and bingo.
Well, at least now I know what that noise that sounded like a bad lifter was.
Now for a little history: I had an issue with the driver's side head when I first installed the motor. https://www.performancetrucks.net/fo...ghlight=vacuumThe #1 and #7 intake runners broke out of the head w/ the rocker arms attached. The place I bought the head from warranteed it and cut me a new one. I asked around and apparently that can happen due to a thin casting or a shift in the casting. Everything's been running fine since, except for that ticking. I should have pulled the lifter tray when I swapped the head, but everything looked fine and I never would have guessed this. Guess I'll be pulling the head again.
I was going to say it was a lifter clip also........but found this thread to late. I have the same GMPP (high performance light weight LS7 lifters). That is scary!!!! Glad to see no other damage was done.....
James
James
James
James
Originally Posted by blown3qtr
I don't think you could blame it on the lifter. The head actually came apart and the rocker arm came out with the chunk of the head it was bolted to. I was at the coast for memorial day when it happened. I had to tow my boat home 300mi on 6 cylinders. That's probably what killed the lifter.
James
