What else could break?
Old Aug 29, 2007 | 07:36 PM
blown3qtr's Avatar
Default What else could break?
I was changing my oil Monday morning. Putting in Mobil one for the first time in the new motor. And this little wire clip comes out with the drain plug. WTF?
Old Aug 29, 2007 | 07:43 PM
dirt track racer 81's Avatar
didnt see nothin like that in my 6.0 i pulled apart..might ask the people that built your 408
Old Aug 29, 2007 | 07:47 PM
nightrunner's Avatar
Mr. Obvious
from here that looks like part of a paper clip
blown3qtr's Avatar
I spent the whole day thinking, "what the hell coul it be?". About the time I figured it out when I was driving home from work, I watched my fuel pressure slowly drop to zero sitting at a light. I had noticed a drop in fuel pressure at WOT Saturday. Damn Walbro 255 went out. Once I pushed it to a parking lot I remembered that the 190LPH bosster pump from the procharger kit was still mounted on the frame rail. I hooked the lines back up and robbed a fuse out of the stereo to supply power to the booster pump. I was up and running again. This time with no loss of pressure at WOT.
Oh yeah so this is what I think the clip is. What do you think?
Old Aug 29, 2007 | 07:49 PM
blown3qtr's Avatar
Thats pretty much what it looks like.
I was wondering if it might have been hanging on the exhaust and the magnet just picked it up when I pulled it out.
Anyway I'm gonna start pulling rocker arms in hopes I can look down and find the broken lifter. If not I'll have to start pulling heads till I find it.
Old Aug 29, 2007 | 07:54 PM
that kinda looks like it..place it on top of the lifter and see if its the same thinkness..kinda looks like the lifter clip is thicker..what kinda of lifters did you stick in it?
Old Aug 29, 2007 | 07:57 PM
blown3qtr's Avatar
It looks to be the same thickness. The shape is a little off but it's probably a little bent too. They're LS7 lifters.
Old Aug 29, 2007 | 08:19 PM
06sierra5.3's Avatar
same shape, same siz, same color...coincidence? start tearin it down. youre lucky it made it all the way down to the oil pan
Old Aug 29, 2007 | 08:49 PM
Bill Reid's Avatar
Got a bore scope? ... maybe pull the pushrods and check the lifters that way...
Bill
Old Aug 29, 2007 | 09:18 PM
ZZebes's Avatar
thats great that you found that but wheres the rest of it???
