What else could break?
Old Aug 29, 2007 | 09:23 PM
jetmann's Avatar
It is definitely A lifter clip! I have seen this many times on early Chevy engines and on one Ls1 that was severely over-revved due to missed shift. If the valve spring is broken or weak, this can happen.
Old Aug 29, 2007 | 10:05 PM
blown3qtr's Avatar
Originally Posted by ZZebes
thats great that you found that but wheres the rest of it???
Right here
I found this on top of the #7 intake lifter after pulling the rocker arms and pushrods. With the lifter retainers you can't see much down the pushrod hole. I stuck a long screwdriver down each hole to hame sure the lifters were all seated. Then I stuck my pen magnet down each one to feel for a loose top and bingo.
Well, at least now I know what that noise that sounded like a bad lifter was.
Now for a little history: I had an issue with the driver's side head when I first installed the motor. https://www.performancetrucks.net/fo...ghlight=vacuumThe #1 and #7 intake runners broke out of the head w/ the rocker arms attached. The place I bought the head from warranteed it and cut me a new one. I asked around and apparently that can happen due to a thin casting or a shift in the casting. Everything's been running fine since, except for that ticking. I should have pulled the lifter tray when I swapped the head, but everything looked fine and I never would have guessed this. Guess I'll be pulling the head again.
Old Aug 30, 2007 | 06:31 AM
ZZebes's Avatar
thank god no other damage was done, i hope it all goes well
Old Aug 30, 2007 | 08:57 PM
454SuperSport's Avatar
what did it sound like?
Old Aug 30, 2007 | 10:57 PM
blown3qtr's Avatar
tapping like a bad lifter or a little like an exhaust leak. It really wasn't too bad. I guess the lifter retainer and spring pressure held it together.
Old Aug 31, 2007 | 01:56 AM
PappyDan's Avatar
Tribe Shaman
still drove you nuts.
Old Aug 31, 2007 | 05:22 PM
closet red neck's Avatar
I was going to say it was a lifter clip also........but found this thread to late. I have the same GMPP (high performance light weight LS7 lifters). That is scary!!!! Glad to see no other damage was done.....
James
Old Aug 31, 2007 | 07:51 PM
blown3qtr's Avatar
James
I don't think you could blame it on the lifter. The head actually came apart and the rocker arm came out with the chunk of the head it was bolted to. I was at the coast for memorial day when it happened. I had to tow my boat home 300mi on 6 cylinders. That's probably what killed the lifter.
Old Aug 31, 2007 | 08:17 PM
I didn't blame the lifter. I was just stating that I have the same lifters as you. Or are you just saying that "I don't think you could blame it on the lifter" just I don't get worried??? Maybe I just took it the wrong way......if so, my bad.
James
Old Aug 31, 2007 | 09:33 PM
Holty's Avatar
Notorious BIG
Did it run ok other than the ticking sound? thats just crazy....
