What does a stall converter do for a cam?
Old Oct 26, 2008 | 09:52 PM
silverado310's Avatar
Default What does a stall converter do for a cam?
Im new to the cam thing and was wondering what a stall converter does? and what the numbers mean besides rpms. Ive heard that you dont drop as much rpms at shifts but what else? does it affect your idle?
Old Oct 26, 2008 | 09:57 PM
1989k1500's Avatar
Most cams move your power band up in the rpm, a looser converter just helps you get up into that rpm faster.
Old Oct 27, 2008 | 08:28 AM
LS1TRUCKGUY's Avatar
use the search function up top. there has been billions of cam and converter threads on here with a lot of helpful info. im sure you will find more than you are looking for.
Old Oct 27, 2008 | 11:49 AM
ZO6Ted's Avatar
Yes, if a certain cam doesn't start to make good power untill lets say 3500, is mismatched with a converter that only stalls to 1800, it would not even be close to the power band on take off and would give up a lot of ET untill it "hits".
Old Oct 27, 2008 | 08:02 PM
dlt76028's Avatar
converters are worth it!! i just shaved off 6 tenths in the 1/8 with a yank 3200 and theres still more left..
LCHEE
Oct 24, 2020 04:10 PM
rednekferlife101
32
Jan 8, 2016 10:42 PM
Dirtywhite
Aug 5, 2015 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
lo&sloSierra
Jul 24, 2015 07:03 PM
