What to do with my 317s
Old Dec 22, 2009 | 04:19 PM
ihdude's Avatar
Default What to do with my 317s
I plan on a cam swap on my LQ4 and was wondering is it worth my time to work on the heads a little. I was thinking maybe milling .040 and 3 angle valve job at a minimum. Anything else I should consider? How much will this cost me?
Old Dec 22, 2009 | 04:32 PM
2005 Silverado's Avatar
SPAM HUNTER
Cost can be different at everyshop, if your going to pull the heads i would do lifters too.
Here in phoenix a valve job, and some bowl work is about 400-500 and that was with milling like .010 to assure straightness.
Old Dec 22, 2009 | 05:40 PM
NemeSS's Avatar
prefer 4angle valve job with 30* backcut on valves, new seals. thinner ls2 head gaskets. mill no more than .030 for correct intake to heads alignment.
Old Dec 22, 2009 | 05:55 PM
ihdude's Avatar
What thickness of head gasket?
Old Dec 23, 2009 | 04:45 PM
NemeSS's Avatar
LS2 is around 4.045 bore .051 compressed
so assuming your piston s around .010 protruding. will have around .041 quench area
Old Dec 23, 2009 | 05:34 PM
ihdude's Avatar
How much tq/hp gains am I looking at from doing the head work?
Old Dec 25, 2009 | 09:45 AM
SweetS10V8's Avatar
I would just save a little longer for a set of CNC heads from Texas Speed for $1025. You can sell your #317s for $200 or so, so the heads will only be $800ish.
They will increase your flow and compression at the same time, youll enjoy it a lot more than a valve job.
Old Dec 25, 2009 | 10:01 AM
Rick_Vor's Avatar
2nd that. A lot more bang for the buck. If you keep an eye on the classified section for a used set of Patriots or WCCH's.
Rick
Old Dec 25, 2009 | 10:24 AM
ihdude's Avatar
So going with the CNC ported heads, what kind of gains can I expect? I plan on a cam that focuses on low end torque.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
11MPG
Sep 10, 2015 08:34 PM
bisqikss
Sep 8, 2015 03:35 AM
