what to do
Old Oct 14, 2007 | 11:28 AM
sclac5.3's Avatar
Default what to do
im thinking about build me a new motor but i dont know what to build a want about 400 rwhp or more on motor. i want it to have a good lop and i need it driveable cuz it will be my DD thank for any help
Old Oct 14, 2007 | 11:33 AM
nightrunner's Avatar
Mr. Obvious
LQ4/LQ9 shortblock
Stage 2 LS6 heads
cam of choice - id think you would want a 224 or bigger
LS6 intake swap
ARP rod bolts, and other hardware
full boltons - https://www.performancetrucks.net/fo...hlight=boltons
built 65e, FLT or performabuilt
3.73s or bigger gears
aftermarket LSD
Old Oct 14, 2007 | 02:07 PM
sclac5.3's Avatar
can i use my bolt on's off my 5.3. im going to change to long tube header tho, i also have a ported and polished tb will it work on the ls6 intake
Old Oct 14, 2007 | 02:28 PM
Mr. Obvious
yes all boltons will swap over from the 5.3 to the new motor.
longtube headers will be much better than the shorties.
yes the P&P tb will work on the ls6 intake, it has the same size inlet as the truck manifold.
the ls6 intake will require car-style fuel rails, injectors, injector wiring harness pigtails, and something will need to be done to the water pump, either a truck pulley pressed onto a fbody pump, a L92 pump
Old Oct 14, 2007 | 02:57 PM
sclac5.3's Avatar
ok thank one more q's would a ls2 block out of a tbss be good to do all this work to and put in my truck
Old Oct 14, 2007 | 03:01 PM
Mr. Obvious
you would be able to get a lq4 shortblock much cheaper.
the ls2 is aluminum GEN4 engine. a few sensors are located differently
