Welp it happened - 427ci lq9 ate it
Old Mar 27, 2018 | 01:01 PM
  #111
03sierraslt's Avatar
I thought they were already installed. My bad
Old May 6, 2018 | 06:16 PM
  #112
Ken in AZ's Avatar
It lives! New Jesel's cause a little bit of a problem and were catching on the edge of the valve cover making a terrible noise like something was bouncing around in a cylinder.
Took them off and clearanced them and reset valve preload and boom, it lives again!
Old May 14, 2018 | 10:57 AM
  #113
Ken in AZ's Avatar
Just an update - seems to be running better than ever. Oil looks good, no weird noises. I'd say I dodged a bullet.
I've put two tanks of fuel through it so far. The only issue I had was the AC wasn't working well on the freeway. $2.29 orifice tube and some fresh refrigerant and it's ice cold again.
Fuel trims are a little off, but that's from switching from the Deka 80's to the ID1050's. WOT it get's close to hitting the AF targets but it needs to be dialed in a bit more. Goes back on the dyno on June 2nd to get the treatment from NicD.
Keep you posted.
Old May 15, 2018 | 08:47 AM
  #114
moregrip's Avatar
what a rush!
Keep you posted.
Glad to hear things are sorted out for you brother! So the only issue was the broken rocker arm?
Old May 16, 2018 | 05:50 PM
  #115
Ken in AZ's Avatar
Thanks, and yeah. One piece, clean break, nothing in the pan. Running like a champ at the moment.
I'm putting the 5.13 gears in the 14 bolt as we speak - I buggered up the pinion bearing...at $110 mistake, but setting up the 14 bolt was a breeze....If I knew it was that easy I would have done it a long time ago.
