Valve spring swap?
Old May 17, 2013 | 01:08 AM
darnie's Avatar
Default Valve spring swap?
I have a 2004 lm7 with ls6 springs im going to be swaping to dual springs for.my turbo. I bought the tool to pressurize the valve so i dont have to pull the heads i was jw what psi do i need to have going into the spark plug hole to keep the valves up?
Old May 17, 2013 | 01:14 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
90-150 psi works. My compressor is regulated to 165 psi, and I don't lower it for this type of job.
Old May 17, 2013 | 09:01 PM
darnie's Avatar
I think mine maxes at 135 its a 30 gallon tank but i can set the valve to make i run say 100 psi orsomthing?
Old May 17, 2013 | 09:23 PM
2000chevysilverado's Avatar
Your good 100 is what I set mine at worked out fine on my last swap
Old May 17, 2013 | 10:26 PM
Yep, 100 psi is just fine.
Old May 17, 2013 | 11:31 PM
GREENSIERRA's Avatar
I used 90psi on both of my swaps
Old May 18, 2013 | 01:21 AM
darnie's Avatar
Ok cool im ill do that then. And i guess just turn the crank by hand and do each one?
Old Jun 9, 2013 | 10:01 AM
Tydriver's Avatar
Any chance you guys have the information on the tool used to do this? I'll admit I'm being a bit lazy, but moreso just want to know what is the preferred tool to do it.. I forsee this swap in my future and I'd prefer to have the preferred tool vs. something I found online.
Old Jun 9, 2013 | 10:36 AM
Chevy_King1500's Avatar
i used 1/4'' nylon rope, good alternative if you dont have air..
Old Jun 9, 2013 | 10:58 AM
Atomic's Avatar
I have a gauge for that
I just turned the crank so that piston is at TDC...
