valve spring replacement
Old Feb 24, 2011 | 09:42 PM
mred's Avatar
Question valve spring replacement
i only have 137K miles and was wondering if any of you guys have changed valve springs,at that kind of mileage on a stock motor 1999 5.3 (factory cam).
i know its probably not necessary but,whats the chances that it could make a difference?
thanks
Ed
Old Feb 24, 2011 | 10:07 PM
06Sierra2's Avatar
probably nobody but i could be wrong. valve springs are the hardest part of a cam swap so if you went to the work of swapping in some springs you might as well throw a mild cam in there at the same time
Old Feb 24, 2011 | 10:26 PM
budhayes3's Avatar
PT's Slowest Truck
+1...I'm sure that there isn't anybody on this site who just swapped stockers for stockers. I have heard of guys running around with 300K on their stock GENIII engines though, so if you use that as a meter, you're not even half way there
If you do decide that you want to swap your springs, get some yellow LS6 springs at the very least...they're inexpensive and will already be in there if and when you decide to swap in a mild cam
chopperloco
Jul 10, 2016 10:45 PM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
