View Poll Results: Which Heads?
WCCH Stage 3 L92's
13
54.17%
AFR 245cc's
20.83%
Trickflow 225cc's
25.00%
Patriot LQ9's
0%
Voters: 24. You may not vote on this poll
Which Heads...
Old Feb 23, 2011 | 06:20 PM
Atomic's Avatar
I have a gauge for that
Default Which Heads...
Next build will be using something better than the stock 317s... may as well go ***** out then, right?
-Used on a 4xx cubic inch, 9.5 compression, probably turbo
-Having PatG spec me another cam
-RCSB truck, non-dd
The ones I am looking at are about the same price, just curious what you guys think.
If other, please specify.
Old Feb 23, 2011 | 06:21 PM
Dewey's Avatar
GEN III or IV?
Old Feb 23, 2011 | 06:22 PM
smokeshow's Avatar
Mod with training wheels
Ported 317s?
Old Feb 23, 2011 | 06:25 PM
Atomic's Avatar
vote in the poll
No preference for cathedral or rect. port at this point...
Old Feb 23, 2011 | 06:28 PM
1slowz71's Avatar
wcch ! ftw !
Old Feb 23, 2011 | 07:45 PM
charcold-bowtie's Avatar
thick deck, aftermarket castings
Old Feb 23, 2011 | 08:54 PM
03sierraslt's Avatar
Voted, now I am going to start a poll on how many polls Atomic will start.
haha, just messin with ya man.
Old Feb 23, 2011 | 10:51 PM
Atomic's Avatar
From what ive read, the 3/8" deck of the heads above is enough for 20psi on average....at that point I am near/past the limit of pump gas with some meth, so its a whole new can of worms to push past that where 1/2" deck heads would be mandatory.... but is there a brand you prefer?
Old Feb 24, 2011 | 12:33 AM
2004SSS's Avatar
what block ? 6 bolt is key imo
with that said , 1/2 studs in place of the stocks also helps alot as lsx motors are known for head gasket issues at higher boost ( i blew one on my 370 from pushing it to hard)
also keep the most CC in the head you can this keeps the deck on the head as well.
i run tea tfs 235 cc 6 bolt heads with all the goodies. they are good to .650 lift( running 619 max) and i also opted to run the 1/2 bbc arp studs for insurance . then you could go even more crazy and o ring the bitch.
if your keeping the stock block and plan on making 1000+ i would 1/2 stud it and o ring it .
now that i didnt answer your question at all. cubic inch is key . if i were doing it again id go with the 245cc head
if i were going with a different style intake port id probably go with something from mast or wcch . trickflows are great but there is better now for the bigger cube guys .
when boosted though a perfect cylinder head isnt needed( 317 can work ) but you will benefit from a aftermarket head quite a bit , not as much as an all out n/a car but a good amount.
block and cubes please???
Old Feb 24, 2011 | 12:39 AM
Atomic's Avatar
See I dont know specifics yet...my block has been at LME for a couple weeks now and they were suppose to have it torn down at the end of last week. I didnt get a call so I called earlier this week and was told the end of this week, so maybe tomorrow or Friday I will know something.
What I really need to know is if the block is still usable without boring the cylinders anymore. They were already at 4.040" and I wouldnt feel that comfortable running any bigger with boost since the cylinder walls are getting thin...if it turns out that cylinder can be fixed with just a hone then I will have the piston replaced and it will still be a 410. If, however, the block needs to be bored, I am very tempted to go with an LSX block and go crazy with those huge *** head studs and 6 bolt heads....but like I said, I should know more by the end of the week.
