Valve spring questions
Old Feb 2, 2006 | 07:56 AM
Fogle07's Avatar
Default Valve spring questions
well i feel like learning something today so i thought why not learn about valvesprings. my question is how do you know which valve spring to use i guess. i was looking at the comp 915 and the 918 springs
915- seat load=105@1.800
open load=293@1.200
spring rate=313lbs
918- seat load=130@1.800
open load=333@1.150
spring rate=313lbs
so how does seat load and open load effect the spring and also why is the open load on the 915 rated at 1.200 and the 918 is rated at 1.150? im sure ill come up with more questions later but this will do for now.thanks in advance
Old Feb 2, 2006 | 09:00 AM
hellbents10's Avatar
LS1Tech Sponsor
Cause the 918 will not hit coil bind as soon. It just depends on what cam you want to run. I would pick the 918 for anything that is more wild then a stock LS6 cam. 220 or more duration @.050 or more then .550 lift.
Old Feb 2, 2006 | 09:50 AM
Fogle07's Avatar
well im not trying to figure out which springs to run im just wanting to learn more about them.
ok now coil bind. i assume that is when the spring is pressed all the way down correct?
Old Feb 2, 2006 | 12:19 PM
zippy's Avatar
correct, that is the point where the coils begin to contact each other.
Old Feb 2, 2006 | 12:25 PM
Fogle07's Avatar
so how does open and seat load correspond with the spring? is that the force that it takes to push the spring down and the force for it to i guess you can call it rebound
chopperloco
Jul 10, 2016 10:45 PM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
