Valve spring question
Old Jan 31, 2006 | 04:20 PM
KLUG'S SS's Avatar
FormerVendor
Default Valve spring question
Would it be okay to run my 918's with this cam- 224/230 581/588 114lsa on XER lobes or should I step up to a dual spring?
Old Jan 31, 2006 | 05:06 PM
Bill Reid's Avatar
The 918 will be a great spring for that cam. 921's are a better spring but not necessary in your case. That is a real nice street cam by the way...
Bill
Old Jan 31, 2006 | 06:44 PM
v8
17,16,15,14,13,12,11 Drvr
the 918's are fine, but if you do decide to change to a dual spring, get the patriot golds, that way you don't have to have your heads worked on to get the springs to work.
Old Jan 31, 2006 | 07:01 PM
KLUG'S SS's Avatar
FormerVendor
Thanks for the quick replys, the lift of the cam wasn't a real big concern for me but I know that the XER lobes are pretty aggresive so I just wanted to be sure.
Old Jan 31, 2006 | 09:32 PM
v8
well you got that big ole 6.0 in there so you should be fine lol, its still going to hurt your lowend, but should gain alot up top to about 6800 rpms.
Old Feb 1, 2006 | 06:34 PM
KLUG'S SS's Avatar
FormerVendor
Yeah that it is the big thing that I am worried about with that 224/230 is how much lowend am I going to lose. Right now I am running a 216/224 Vinci cam and my truck has good lowend power but I would like more power up in the rpm range.
Old Feb 3, 2006 | 03:04 PM
ZR1 DREAMING's Avatar
is the 216/224 to "light" for the LQ9? I'm still looking at different cams and am gathering as much info as possible-> my bad on being
chopperloco
Jul 10, 2016 10:45 PM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
