Valve float
Old Jul 25, 2006 | 02:09 PM
tdrumm's Avatar
It's they are what VHP recommended with the cam. I got them as a set.
Old Jul 25, 2006 | 02:29 PM
TurboGibbs's Avatar
If the springs are too stiff the lifters will compress and you won't be getting full lift. But if they recommended them then surely you are good.
Lifter compression is what makes a solid roller cam different than a hyd roller. A solid has more agressive lobes (opening and closing rates) since you can run a much more stiff spring on them.
Old Jul 25, 2006 | 02:38 PM
tdrumm's Avatar
So it sounds like I shouldn't have any valve float problems, which is a relief. Back to saving up for the next round of mods in the sig.
Old Jul 25, 2006 | 04:26 PM
CamKing's Avatar
You are not having a valve float issue. When you have valve float, the power curve doesn't level off, it falls off a cliff.
If the power curve is leveling off, it is most likely because the intake port, Manifold, or headers are too small and are restricting the air flow.
Old Jul 25, 2006 | 04:49 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I have that cam and those springs and stock rockers and everything runs great.
Old Jul 26, 2006 | 06:18 PM
budhayes3's Avatar
PT's Slowest Truck
I'm thinking you're gonna need a better flowing intake for what you have planned...
Old Jul 27, 2006 | 12:36 AM
im pretty sure with the cams alot of us have on our trucks most of us should be looking for a better intake
Old Jul 27, 2006 | 05:52 AM
tdrumm's Avatar
Yeah, just needed some reassuarance that I didn't have a problem before I go any further.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
