used crank in another motor?, iron ls1
Old Mar 30, 2009 | 12:33 PM
silver-mod-o's Avatar
Hunt&Fisherator
it should work, I'd double check the stroke numbers.
to go with a used crank though, just like everyone has said, use new bearings, check your tolerances, and balance the roatting assy and you'll be in good shape, this is done every day.
Old Apr 1, 2009 | 01:42 PM
lo&sloSierra's Avatar
whats the deal with the reluctor wheel, do i need the 58x? i found that i can get a ls2 crank but i think it has a 58x reluctor wheel, i dont know what the difference is
Old Apr 1, 2009 | 05:12 PM
Hunt&Fisherator
damn, I forgot completely about the reluctor.... GEN III will need a 24x wheel.... GEN IV takes 58x. somebody correct me if I'm wrong.
Old Apr 1, 2009 | 08:48 PM
ok so my truck is an 03, so i believe that is still genIII, ok thanks
Old Apr 1, 2009 | 10:20 PM
budhayes3's Avatar
PT's Slowest Truck
That is correct sir
Old Apr 4, 2009 | 02:22 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Its probally a 58x wheel and you will either need a converter box for the signal or swap it for a 24x wheel. Would have to call for more details. I am sure you could get a nice used crank with a grind for less the that though... Remember 5.3 and 6.0 use the same exact crank as the 5.7 LS1. A true LS1 crank has a 1 inch hole gundrilled through the center main journals. Is one better then the other??? Who knows for sure. Alot of theory, speculation, and hearsay. Its said that the 5.3L cranks are the easyest to balance when adding forged pistons and rods. Ironicly there usually the cheapest too if you look hard enough. I always see truck cranks listed as LS1 cranks so that they can sell them for more money, so watch out for that trick.
Old Apr 4, 2009 | 08:15 AM
ssavalanche's Avatar
4.8 stroke=3.25, 5.3/5.7/6.0/6.2 stroke=3.622, 7.0 stroke=4.0. 24x reluctor is in 97 to 05 for sure in cars, 58x is 06 and current. The trucks may have kept the 24 a little longer, but I can't remember exactly. But the external key to look for is a white crank sensor. That means 58x ring.
Old Apr 6, 2009 | 05:22 PM
Slimsilverado's Avatar
Thanks for the info SS, I have been thinking about turning my 5.3 into a 5.7 also but then again i could get a eagle stroker crank and make it a 383 also..... If your gonna buy a crank why not stroke it as much as you can...
TXsilverado
Nov 26, 2015 10:54 AM
black00chev
Aug 12, 2015 01:56 PM
Denali08
Aug 9, 2015 04:34 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
jmarkway
Jul 18, 2015 09:23 PM
