Two Types of Valve Seals?
Old Mar 17, 2010 | 09:37 PM
Ferocity02's Avatar
Default Two Types of Valve Seals?
Are there two types of valve seals for the 5.3L truck engines? I'm ordering some replacement parts and I see some that look like they have the spring seat as part of the seal. And then theres the seals that just press on, which are the ones I'm used to. Anyone know which ones I need... '01 ECSB 5.3L, 2wd. Thanks!
Old Mar 17, 2010 | 10:13 PM
2000chevysilverado's Avatar
the factory ones just slip on, the intake are a different size than the exhaust side smaller or bigger cant remember of hand but you can order them from patriot or orielys
Old Mar 17, 2010 | 10:22 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yours will have the spring seats built in, thats what were on my stock motor.
Old Mar 18, 2010 | 12:09 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you're running the stock valve springs, then you need the ones with the spring shim built in.
Old Mar 18, 2010 | 12:51 AM
Ferocity02's Avatar
What the part number for these? I will be running LS1 springs, are those considered "stock"?
Old Mar 18, 2010 | 12:58 AM
Yes, considered stock. Your local dealer will have part numbers. As stated earlier, the intake and exhaust are different part numbers.
Old Mar 18, 2010 | 02:57 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mike, lol, I'm in the same boat as you going from a HOSS to a truck. Some stuff is completely different.
Old Mar 18, 2010 | 03:05 AM
Ferocity02's Avatar
The Z was so much simpler... trucks are weird.
Old Mar 18, 2010 | 03:07 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
true that.
Old Mar 18, 2010 | 07:50 AM
budhayes3's Avatar
PT's Slowest Truck
LOL...you think they're wierd, I think they're simple Hang out around here long enough and the trucks will become second nature
