TSP vs. TR cam lobes??
Old Nov 4, 2010 | 04:44 PM
03 True Fire's Avatar
Default TSP vs. TR cam lobes??
Guys ive been doing some research trying to get my set up all figured out for my next truck.. and ive been doing some research and just wondering if there is a significant difference between the Texas Speed & Perf. cam lobes compared to the Thunder Racing lobes? looks like from the info i have gotten the TSP lobes are better? any info or insight is appreciated.
Thanks,
Chase
Old Nov 4, 2010 | 05:37 PM
jrmchevyman's Avatar
Thanks,
Chase
I believe Texas speed has slightly more aggressive lobe profiles over thunder racing. Also when comparing the 2 companies same cam like the TR 220 vs TSP 220 Texas speed has more lift than the Thunder racing does.
Thunder Racing 220 cam has .551 lift and the TSP 220 has .581 also the TSP 224r has .581 too.
You could always get a custom ground cam though.
Old Nov 4, 2010 | 09:36 PM
holler at me bro!!! u figure out what ur gettin yet?
Old Nov 4, 2010 | 09:59 PM
GMCtrk's Avatar
EPS cams are designed by the same guy as the TR cams, but use newer lobe tech, supposedly are easier on the valvesprings. They do that while managing higher lift as well.
Old Nov 4, 2010 | 10:16 PM
for sure brother i'll hit you up tomorrow man.. looks like i might be getting a truck soon!
Old Nov 4, 2010 | 10:19 PM
so basically the tsp cam just has a higher lift but the tr lobes are better? ive been reading it the other way around from other threads. correct me if im wrong?
Old Nov 4, 2010 | 10:55 PM
budhayes3's Avatar
PT's Slowest Truck
TSP uses Comp XER lobes while TR uses their own proprietary lobes, which are ground by Comp. Both are proven, but I'm not sure which one is "better"...
5.3Okasai
Mar 9, 2022 01:07 PM
TXsilverado
Nov 26, 2015 10:54 AM
vmaxpro
Jul 27, 2015 10:45 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
