TR Blower Cam w/ Radix
Old Nov 20, 2006 | 09:08 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by FarmerBeau
Id say be unique and get a custom grind. I could buy a TR220 to make me hit 12s but then again, i can get a custom grind and be unique. Cmon Brandon....Dont be a conformist. JFWY
Or you can buy a custom one and run 14s
Old Nov 20, 2006 | 09:35 PM
Stoichiometric's Avatar
If you were to get a custom grind would you go bigger on the lift/duration and keep the 117 CL? Or go bigger lift/duration and tighten the CL a bit?
Old Nov 20, 2006 | 09:41 PM
For a roots type blower, 115 - 117 LSA is perfect. I don't think I would go any bigger on a 5.3.
Old Nov 20, 2006 | 09:59 PM
if i were to change the durations of that cam i would make the split greater or change it to a reverse split but you have to make sure you keep negative overlap and a high LSA
Old Nov 20, 2006 | 10:11 PM
FarmerBeau's Avatar
Sexy Party Mod
Or how about talking **** when my truck hasnt run in 4 months...... Below the belt to you too!!!!
Old Nov 20, 2006 | 10:12 PM
1slow01Z71's Avatar
Or i can talk **** when my truck hasnt run in 4 months...... Below the belt to you too!!!!
you know I love you Beau, I have no room to talk but you gotta admit it is fun
And get it right I havent drive the bitch in 6 months
Old Nov 20, 2006 | 10:16 PM
FarmerBeau's Avatar
Sexy Party Mod
It is hilarious....I put down a 13.8 with a shitty verter..... I am whoring the **** out of this thread.
And you also have no room to talk about the custom grind business....Did you not get you a Mike Jones cam a while back?..(who?...mike jones..what ....Mike jones)
Brandon, The reason i say a custom grind may be better is because you would be able to control your overlap, DCR, etc and not just settle for something that was premade. Its a gamble sometimes but then again, you still remain unique. I dont like to do what everybody else is doing.....Call me crazy.
Old Nov 20, 2006 | 10:29 PM
onebadrubi's Avatar
I see alot of people braking driveshafts around here.
haha figured I would join in on the fun.
Old Nov 20, 2006 | 10:42 PM
1slow01Z71's Avatar
Brandon, search the user Charris. He had a H2 with a 6L and radix, he had the trak cam if I remember correctly then switched to the gt2-3 and said it was a much better cam and I believe he dropped a tenth or two.
Old Nov 20, 2006 | 11:14 PM
What type of effect would he see from a reverse split on his application? How wide of a LSA is too wide? Maybe I shouldn't use someone else's thread to answer some of my own cam questions
