TQ spec's on head bolts
Old Aug 4, 2006 | 09:08 PM
1SlowHoe's Avatar
Destroyer of Transmissions
The trick I read about, and used, was to draw a line across all the bolt heads with a black sharpie marker. That way you can see when you've gone exactly 90* etc...
If you use molly lube instead of oil I think the TQ specs are different.
Old Aug 4, 2006 | 09:14 PM
goshawk23's Avatar
Truck addict
oneslowhoe i think you are correct. oil vs molly lube will have different tq specs. my numbers were based on oil. i don't keep things like this in memory so i have to cheat and look. they used regular oil. 30wt
Old Aug 7, 2006 | 08:20 AM
silver-mod-o's Avatar
Hunt&Fisherator
I got the specs plus the little sharpie trick off of LS1 howto when I did ZO6 DREAMING's heas the instructions were for an F-body but I am sure its all the same. his went in fine and he hasnt had any problems... even reusing the stock head gaskets with 11.5:1
slowlsx
Aug 10, 2015 05:33 PM
Denali08
Aug 9, 2015 04:34 PM
JordanH
Aug 8, 2015 07:59 PM
NuckenFuts
Jul 9, 2015 08:45 AM
