Torque spec's for ARP rod bolts?
Old Aug 28, 2005 | 08:19 PM
speedy02's Avatar
Question Torque spec's for ARP connecting rod bolts?
What are the Torque spec's for ARP connecting rod bolts? Any different then stock?
Thanks
Old Aug 29, 2005 | 01:38 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Not sure, but the last set I saw had directions which gave a 1-800 # to call if you had questions. I don't think they use the same tq as stock. The only reason I know is because I watched a guy snap one and THEN call for help.
Old Aug 29, 2005 | 04:39 AM
Just did a set on friday. Theres a paper inside and that tells you. You torque them to 45 ft lbs and loosen them, then torque again to 45 ft lbs and loosen them, and a 3rd time torque them to 45 ft lbs. Thats what the directions say. Also use their lube for the threads and under the head of the bolt.
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
