5.3 Piston swap
Old Aug 26, 2005 | 01:23 PM
OldNovaGuy's Avatar
Default 5.3 Piston swap
I have my 5.3 at the machine shop having some work done and they are having trouble getting my paistons off the rods without having them crack. I wouldn't worry about it but they are yaking a set of 4.8 pistons (Flat top) off the stock rods to put on my 5.3 rods and they fear this will occurr on them also. Is there a trick to this procedure?
Old Aug 26, 2005 | 01:28 PM
gonzo 6.2's Avatar
Have them bore it and install 5.7 hyperutectic pistons in.They run around $25 each
Its risky trying to get off used pistons to be re-used,going back in is easy though,they heat the pin.
Old Aug 26, 2005 | 04:06 PM
BigMone's Avatar
get your parts back and run a way......
Old Aug 29, 2005 | 04:42 AM
They don't sound like a very good machine shop. I did my own last weekend in my own garage. You just heat the small end of the rod so the pin will go in or out. I had no problem whatsoever.
ferrellrooster
Mar 6, 2025 03:22 PM
5.3Okasai
Mar 9, 2022 01:07 PM
4B11T
Jul 13, 2015 03:48 PM
kdw8888
Jul 9, 2015 10:52 PM
NuckenFuts
Jul 9, 2015 08:45 AM
