ticking
Old Aug 21, 2007 | 12:25 AM
xdanny510x's Avatar
Default ticking
should thier be loud tickign from the valves.. i recently installed a cam on saturday and in the mornings and when the truck is cold and i start it up it makes a ticking sounds 4rm the valves... is this normal? or should i start usinig a thickier motor oil because right now im using 5w-30 synthetic.. or any suggestions/
Old Aug 21, 2007 | 12:51 AM
ZZebes's Avatar
jump to 10W30 and since you have aftermarket springs they will be louder
Old Aug 21, 2007 | 07:23 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yup, tick tick tick etc etc.
You'll get used to it.....not!
Old Aug 21, 2007 | 07:52 AM
ZR1 DREAMING's Avatar
You don't need to change oil weight.
It's normal, welcome to the LS motors.
Old Aug 21, 2007 | 08:00 AM
slowec's Avatar
My ticking lets me know my engine is still running. If people hassle you, tell them your solid lifter 3/4 cam is suppose to do that.
Old Aug 21, 2007 | 08:17 AM
DixieDevil's Avatar
Good to know! Was hearing it in my truck today again and started to worry me!
Old Aug 21, 2007 | 08:26 AM
TouchOfEvil04's Avatar
Mine does all the time....reminds you she's still doin what she was ment to do.
Old Aug 21, 2007 | 09:51 AM
Yogi Bear's Avatar
Did you use stock length (7.400") pushrods? Maybe your new cam has a smaller base circle and you need longer pushrods to make the hydraulic lifters work right. Pushrods that are too short will also reduce valve lift and duration - which will cut your performance some.
Old Aug 21, 2007 | 11:59 AM
Silver-Dollar's Avatar
mine as well. Just remember to let them warm up a bit before putting to many rpms to them. Hell, when it is 80 degrees at 6 o'clock in the morning, I still will let it sit idling for a least 2 minutes before I put it in drive.
Choda
Jun 5, 2025 06:43 PM
97_ek
Sep 23, 2015 09:16 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
lxcoupe
Jul 27, 2015 08:19 PM
chvy=power
Jul 27, 2015 10:06 AM
