Thrust bearing toast??
Old Jun 20, 2013 | 11:44 PM
oakley6575's Avatar
Damn that sucks to see. It must move a pretty good amount to hit the main cap like that. Any idea what clearances the machine shop build the shortblock to?
Old Jun 21, 2013 | 08:12 PM
SlickSierra's Avatar
Not sure but if it can be fixed im getting a spec sheet of the tolerances
Old Jun 22, 2013 | 09:47 PM
Gadgetized's Avatar
When you unbolted the converter, did it slide back from the flexplate?
Old Jun 27, 2013 | 04:34 PM
Not that i noticed
Old Jul 10, 2013 | 12:36 PM
moes04silverado's Avatar
Originally Posted by SlickSierra
Not that i noticed
it should have a little - my 370ci did they same thing-toasted thrust bearing caused by the converter balloon. I had no play from flex plate to converter to trans - NONE. every converter will balloon some; how much is the question. My problem was I had the older style crank with a 4L60 which isn't suppose to work, but I got it all to fit but very very tight. I was on a three hour cruise with the timing all went to **** b/c I had too much end play in the crank from toasting the thrust bearing; Motor is getting overhauled now and a new 5.3/6L crank installed with the shorter .50" end for the 4l60.
Old Jul 10, 2013 | 10:19 PM
^ You bolted up the longer crank to a 60e??
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
Velocity1
Sep 22, 2015 01:32 PM
600 horses
Sep 10, 2015 11:01 AM
