<TECH ONLY> Calculating Compression Ratio
Old Aug 10, 2006 | 12:27 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default <TECH ONLY> Calculating Compression Ratio
Math:
Formula 1:
CR =
[{(B/2)^2 * S*Pi}+Vcc+Vp+{(B/2)^2*Pi*(DH+TG)}]
[{(B/2)^2*Pi*(DH+TG)}+Vcc+Vp]
Where:
CR= Compression Ratio
B = Cylinder bore
S = Stroke
Vcc= Combustion Chamber Volume
Vp= Piston Volume
DH = Deck Height
TG = Head Gasket Crush Thickness
Pi = 3.1415
Formula 2: (I prefer this one)
Compression Ratio = (GV+DV+HV-VV+PV) / (GV+DV+HV-VV)
GV (Head Gasket Volume) = Bore(in) X Bore(in) X 12.87 X (Head Gasket Thickness in Inches)
DV (Below Deck Volume) = Bore(in) X Bore(in) X 12.87 X (Inches Below the Deck)
HV (Head Volume) = CC's
VV (Dish, Valve Pocket, Dome Volume) = CC's
(Minus for dish or valve pockets, Plus for dome)
PV (Volume displaced by Piston) = Bore X Bore X Stroke X 12.87
Some links:
Smokeup's CR Calculator
Smokeup's Dynamic CR calculator
Old Feb 6, 2011 | 12:07 AM
1SlowHoe's Avatar
Destroyer of Transmissions
This is the one I've been using:
http://www.race-cars.net/calculators...alculator.html
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
1989k1500
Sep 29, 2015 10:53 AM
