Tbss/nnbs intake on 01 5.3?
Old Jan 13, 2013 | 12:20 PM
1_MEANZ28's Avatar
10 Second Club
Default Tbss/nnbs intake on 01 5.3?
Looking buy an intake.i was told that the tbss intake can fit my truck.is it direct fit? Any modifications needed? Power gains? Thanks for your time
Old Jan 13, 2013 | 12:34 PM
02chevyls1's Avatar
It's a direct fit but you need to buy a corvette fuel filter that connects your stock fuel lines to the new intake your fuel system is return style and the tbss is return less and the corvette filter is a direct snap on fit to convert it when I did mine I did the swap with headers and I think it was like a 30 rwhp gain if you use your stock injectors they will fit and work in the new rails no problem if you use the tbss ones your gunna need wire connectors for the injectors
Old Jan 13, 2013 | 01:09 PM
1_MEANZ28's Avatar
10 Second Club
Thanks alot for the info
Old Jan 13, 2013 | 01:33 PM
N/ALS1's Avatar
What are the TBSS injectors rated at?
Old Jan 13, 2013 | 01:41 PM
texasglock23's Avatar
30rwhp? Damn, I need to scoop one up then
Old Jan 13, 2013 | 02:50 PM
dmelvin's Avatar
It seems to only be a peak number. Gray_Matter04 took his off and sold it as his track times got slower after he installed it.
Old Jan 13, 2013 | 03:34 PM
low2001gmc's Avatar
interesting. every fast 6.0 ive seen has one.
Old Jan 13, 2013 | 03:38 PM
Sexyrado327's Avatar
I'm about to install one on my truck along with the 87mm throttle body plus removing cats and a posi. Kinda stoked to see the difference
Old Jan 13, 2013 | 05:59 PM
GREENSIERRA's Avatar
I found it to be a very good mod
Felt a difference throughout the entire power band
Old Jan 13, 2013 | 07:31 PM
Ferocity02's Avatar
Anyone got a link to the Corvette regulator? Does it truly install without any modification to the fuel rail or fuel lines?
Who makes cable TB's that will work with this intake and with the stock throttle and cruise cables?
Are the fuel injectors the same height?
