TBSS intake vs stock
Old Nov 25, 2008 | 09:28 PM
  #81
MGMC's Avatar
12 Second Club
Originally Posted by skyhighsami
Can you use the injectors that cam with it, and what are they rated to?
they are rated around 28-29lbs, but the connectors are uscar witch is the car style injector connector. i know the 08's and up have those connectors, im not sure about 07 and 06 and below have the delphi ones. if 28-29lbs is enough, i know racetronix makes a connector adapter for them. im not sure of it would be worth it $$ wise, the prices need to be researched.
-mike g
Old Nov 26, 2008 | 07:38 AM
  #82
skyhighsami's Avatar
no title here
I was told they had 34 lbs injectors
Old Nov 26, 2008 | 07:27 PM
  #83
MGMC's Avatar
12 Second Club
I went through this issue when i sold the stock ones on the manifold i have. a fella with a 08 tahoe, norris_83 i belive needed some injectors. the tbss ones had the same duty cycle as his stock injectors. 28-29lbs is what what we came up with...........
Old Nov 26, 2008 | 07:30 PM
  #84
MGMC's Avatar
12 Second Club
here is the thread i started when i was researching...
http://www.tbssowners.com/forums/showthread.php?t=19136
Old Nov 26, 2008 | 07:34 PM
  #85
no title here
So what would the stock injectors in my 03 1500 HD be? If these will provide enough fuel for my head and cam combo then I will run them. I have no plans for FI or N2O so I think they will be fine if the 8.1s work at 31 lbs
Old Nov 26, 2008 | 07:36 PM
  #86
MGMC's Avatar
12 Second Club
~24lbs i think.......let me see if i can find some proof
Old Nov 26, 2008 | 08:39 PM
  #87
hog's Avatar
hog
22 pph at 43.5 psi(3BAR) or 25.4 pph at 58 psi (4 BAR) of fuel pressure. Same for the 4.8/5.3/6.0 trucks 01-04.
peace
Hog
Old Nov 26, 2008 | 09:11 PM
  #88
no title here
So you are saying the TBSS injectors are the same as the 01-04 trucks?
Old Nov 26, 2008 | 09:17 PM
  #89
Truckshop's Avatar
the flow rate table on a tbss tune says they are 33lb injectors.
Old Nov 26, 2008 | 09:23 PM
  #90
no title here
Awesome, so they would be more than enough for me if the 31lb injectors from an 8.1 would be enough. Now I need to see if they will just plug in to my stock harnesses.
