TBSS intake vs stock
#51
So with this intake you can run the marine injectors, and the run the Corvette throttle body with the harness? I am just making sure because I was looking a building a 6.0 I have for my truck with ported heads and a mild cam. Thanks
#52
doesnt have to be the marine injector. any of the ones that fit your truck will work from the info i have gathered (as long as you use the tbss fuel rail). i plan on running my regular 8.1's when i do the intake swap with my 243's
#53
Did you do it yet hirdlej? I just installed some stock 243's and a 08' tbss intake/tb. The truck feels great and ill be heading to the track on wed next week for some times if the weather holds
#55
On your truck I'd bet you'll see a 10-15hp and 20ftlbs of torque gain which is great since I doubt you'll lose any drivability out of it. It should be an over all gain once you get it dialed it. You'll notice the difference right away when tuning it.
btw, got my idle clip. I'll be posting that tomorrow.
#60
