TBSS Cam Specs?
Old Apr 15, 2010 | 09:04 PM
02RedHawk's Avatar
Same as '01 LS6 - 204/211, .525".
Old Apr 16, 2010 | 12:11 AM
budhayes3's Avatar
PT's Slowest Truck
What are the LSA's on those cams, are they the same?...I know that at least one of them is a 116, and I believe that the TBSS cam is a single bolt as opposed to a 3 bolt for the LS6 cam...
Old Apr 18, 2010 | 12:05 PM
02RedHawk's Avatar
Yes they are the SAME. The TBSS is an LS2 = GTO LS2 = Corvette LS2 = Same cam as '01 LS6. In 07+ the TBSS went to the 58x reluctor and single-bolt but cam specs were identical as the 06.
Old Apr 18, 2010 | 02:19 PM
acethedragon's Avatar
your right it is an ls2 but specs are 207/217, .525/.525 around 116 or 117 lsa. any ls2 specific cam will work. the difference is the cam sensor moved to the front cover instead of the back of the block
Old Apr 18, 2010 | 06:08 PM
budhayes3's Avatar
PT's Slowest Truck
and the newer ones have the one bolt cam gear...
Old Apr 18, 2010 | 06:52 PM
02RedHawk's Avatar
Nope. GM-Parts' recent info "release" with the '01 LS6 production-cam as a 207/217 is incorrect.
204/211, .525" 116 LSA is correct, verified by a number of cam-docter'ed cams and by previous GM Engineering publications / press releases. LS2 cam = '01 LS6.
Also for ref:
http://www.idavette.net/hib/02ls6/page2.htm
https://ls1tech.com/forums/generatio...cs-please.html
http://forums.corvetteforum.com/c6-t...s2-vs-ls3.html
'02+ LS6 Cam was slightly bigger & more lift than '01 (resulting in the extra 20hp over '01) and is a 204/218 .55x" 117.5 LSA
And LPE's slightly bigger "LS6 cam on steroids" GT2-3: 207/220 .58x" 118.5 LSA, which makes the most power of this very-similar bunch.
Old Apr 18, 2010 | 07:33 PM
i sit corrected. thanx for all the info. very helpful
Bluchevypick
Aug 18, 2015 09:11 AM
lawhitediamante
Aug 12, 2015 12:14 PM
OLD BULL
Aug 1, 2015 05:00 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
