surface rust in piston sleeve
Old Dec 11, 2007 | 12:07 AM
TXsilverado's Avatar
best method to get the rust out? theres a good amount haha.
Old Dec 11, 2007 | 12:12 AM
FarmerBeau's Avatar
Sexy Party Mod
you cant rub it off with some oil and a terry cloth?
Old Dec 11, 2007 | 12:15 AM
RandomHero's Avatar
Originally Posted by dirt_track_racer_81
water dispersing or somethin like that..40 was the 40th try..made for the military to dry water out of electrical connections or somethin like that..not even made for lubrication..i never use it
Well my point was that is stands for water displacement which is supposedly the same concept behind pb blaster.
Old Dec 11, 2007 | 12:25 AM
moregrip's Avatar
what a rush!
my personal fav is MMO
Old Dec 11, 2007 | 12:53 AM
i aint liking this guys. terry cloth + oil, carb cleaner, or pb blaster isnt wiping it off. the truck will run tomorrow. i figure the pistons can clean off the cyl walls better than i can.
Old Dec 11, 2007 | 02:14 AM
jakebdb56's Avatar
with genI motors it wasn't anything to worry about if it was only from a day or so. Did you try brake cleaner? Unless it's a bunch I wouldn't worry about it, but I'm no guru lol. funny thing you mentioned wally world, the other day they carded me for buying sharpies and not a can of carb cleaner. pretty ****** stupid.
Old Dec 11, 2007 | 11:00 AM
Yogi Bear's Avatar
Terry cloth isn't rough enough. Try a ScotchBrite pad wetted with the PB Blaster.
Old Dec 11, 2007 | 11:02 AM
Tootall's Avatar
hose it down with some WD-40 or put some oil the walls and spread it around with your finger . . . unless the rust is "flakey" don't worry about it.
Old Dec 11, 2007 | 11:13 AM
ive already decided that its starting tonight. all i gotta do is drop on the heads and top end. injectors are already swapped, gaskets and bolts are here, its all down hill from here.
Old Dec 11, 2007 | 11:26 AM
Tootall's Avatar
take some pics if you can !
