stupid 5.3 question
Old May 5, 2009 | 06:53 PM
ryan_wagnon's Avatar
Default stupid 5.3 question
Hey im trying to install a cam in my 5.3 in my 2000 silverado is this a hard job and do you have to pull the heads. Thanks
Old May 5, 2009 | 07:03 PM
sonoma43's Avatar
no need to pull the heads, it is the easiest cam swap I have ever done on any motor...ive worked on many sbc and bbc and the LS motors are so easy to do cam swaps in. search around there is plenty of info you guide you if u need help.
search for the ls1howto write up on cam swaps that is the perfect step by step instructions with pics
Old May 5, 2009 | 07:07 PM
Mangled03gmc's Avatar
Baltimore Whore
http://ls1howto.com/index.php?article=23
Follow this, you will be fine.. Same in the car as the trucks, act the trucks are a tad easier.. You don'y have to pull the heads.. KEY THING TAKE YOUR TIME..
lukesdad04's Avatar
You don't have to pull the heads unless you plan on changing the lifters. Most folks don't change the lifters unless you have a ton of miles on your motor. There are several cam swap threads on this site, just use the search icon and type in cam swap.
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
