Stumped :(
Old Jan 11, 2010 | 03:50 PM
Lightning Killa's Avatar
Default Stumped :(
Hey, so I recently bought a 2004 lq4 short block for 800 bucks. After assemebling the block we put in my truck. A few minutes later we hear a ticking nosie. Turns out to be that piston 5 bearing spun. So I take the motor out fix it and put it back in. Started up the truck and ran fine for about an hour. Park in and I happen to see smoke comming out, open the oil cap and Blow by is present. Did a compression test and all cylinders were at 150 except for cylinder 7 which was at 100. SO could this be bad piston rings, or bad valve guides. Im Stumped..
Old Jan 11, 2010 | 03:51 PM
thunder550's Avatar
High on diesel fumes
Seeing as how it's #7 I'm going to guess that it's got a broken piston. That's a common cylinder to have go lean. Seen a lot of guys here with broken ringlands from detonation.
Old Jan 11, 2010 | 03:55 PM
Exactly what I didnt want. Bummer!! Thanks for the quick reply. I spoke with the guy whom I bought the motor from and he said that they will take care of it. Keeping my fingers crossed!!
Old Jan 11, 2010 | 04:05 PM
thunder550's Avatar
Good luck, keep us updated!
Old Jan 11, 2010 | 04:07 PM
SILVERADO11's Avatar
That sucks man. good luck!
Old Jan 11, 2010 | 05:20 PM
hirdlej's Avatar
Cracked ring or broken ring land, good luck!
Old Jan 11, 2010 | 05:26 PM
stock48's Avatar
9 Second Truck Club
Man that sucks someone must have ran the **** out of that thing. Do you know what they were doing with it in it's previous life?
Old Jan 11, 2010 | 06:59 PM
The motor was out of a burned truck. The yard wanted 500 for it and he told me for another 300 he would put new rings and bearings. So i thought i got a pretty good deal for 800. I guess not right...
Old Jan 12, 2010 | 01:25 PM
BlownChevySS's Avatar
My motor was running lean for awhile. I have ~66k miles and just did my rings and had a valve job done. Do a leakdown test to be sure where you are losing compression
Old Jan 12, 2010 | 04:52 PM
well here is a video of how the smoke looks... I am going to do change out the valve guides..
http://www.youtube.com/watch?v=iVQ40qRUoeg
