Stroking an LC9 5.3?
Old Dec 27, 2015 | 02:18 PM
0235SS93's Avatar
Default Stroking an LC9 5.3?
Hey guys, I have a 2013 low mileage 5.3 block I'm building for my dd. It'll be a torque oriented build that will spin less than 6500rpm. Top end will be mildly hand worked 243s, nnbs intake manifold, and a comp 212/218 hi lift on a 112 lobe sep. I want to use a 4" stroke crank with the stock 3.780 bore, but that puts me in an odd piston selection. The only pistons made for that combo use a .927 wrist pin. If I'm understanding right, my stock gen 4 rods are .945 pin, although I've read otherwise. I really wanted to build a really cheap torque focused engine. If I'm gonna have to buy rods, crank and pistons, I might as well go big. The pistons made for that application have a compression height of 1.100". Stock is roughly 1.324" I believe. Stock rod length is 6.098", whereas I've seen this combo done with 6.125" rods with 1.1" ch pistions. The pistons are available with the .945 wrist pin, but only in a 1.3" compression height, which is designed for use with stock stroke and rods. Do you guys see any alternative here? Or would I have to do a complete rotating assembly to achieve the 5.9L stroker? Stock rods and pistons would come out of the hole too far I'm sure.
Old Dec 27, 2015 | 03:11 PM
George C....'s Avatar
Formerly ScreamingL
Money youll have in that motor you could build a 402 for similar price
Old Dec 27, 2015 | 06:54 PM
06 4.8's Avatar
Yup!!
Old Dec 27, 2015 | 07:05 PM
0235SS93's Avatar
The point of this thread is to see if anyone knows of a piston that would work so I don't end up buying a complete rotating assembly. Which, if that's the case, I'm going to 3.905 bore and 383ci.
Old Dec 27, 2015 | 07:16 PM
Formerly ScreamingL
Still wouldnt build a 383 when same cost for 402
Old Dec 27, 2015 | 09:01 PM
0235SS93's Avatar
I'm using a stock aluminum block with stock liners.
Old Dec 27, 2015 | 09:04 PM
Formerly ScreamingL
Cost to build a 383 is same price as 402
Since they use same crank same rods and pistons cost same.....
Old Dec 27, 2015 | 11:14 PM
0235SS93's Avatar
But wouldn't 4.000 bore leave me with very little liner thickness on the stock liners?
Plus, if I do 383 or smaller now, I can always go bigger later with just a piston change. Can go down in size if something doesn't play right.
Old Dec 27, 2015 | 11:19 PM
0235SS93's Avatar
Not to mention the skirt wear associated with 4"+ bore on a 4" stroke. The original intent of this thread was to find out
1) are gen 4 rods .927 or .945 wrist pin?
2) could a 359ci engine be built from a 5.3 without buying all aftermarket rotating components?
Old Dec 27, 2015 | 11:26 PM
0235SS93's Avatar
If I had a wrist pin or rod at home, I'd just measure it. But everything's at the shop. If the gen 4 rods are indeed .927 wrist pin, the wiseco makes a piston that will work with 4" stroke and stock 6.098" rods. Giving me the exact combo I desire
