Stroker Motor Build For Towing
Old Dec 22, 2012 | 02:12 PM
  #101
swift700's Avatar
The low-end torque will be insane. Can't wait to see the numbers. Congrats on a very nice build.
Old Dec 22, 2012 | 03:49 PM
  #102
Duntov1967's Avatar
Wow, thats is BABY cam for that setup. My cam is quite a big bigger on less CI and my bottom end is great, you may fall off on top end. What RPM do you plan to shift at?
LOL. I guess my cam really should be called a 'fetus' cam. My build isn't typical for this forum which is mainly street/track racers. I am pure 4X4, 33" tires, 6,000 lbs. of boat hauler and only care about torque. High rpm is a detriment because wheel spin is a negative for us dirt guys. Controllable power down low is where I'm at. I guess I will be shifting around 5K - 5.3k rpm.
The cam I am using is to gain as much torque down low, idle like stock, get decent fuel mileage and just maybe a stop light match with some kid in a ricer. I am 60 now and my days of broad sliding at 120+ mph are over. So for now, I will keep my old Tahoe looking stock with its single exhaust (3.5" Duramax diesel) and enjoy the kick in the butt.
I don't have a lot of experience with LS motor cams but the Pat G spec'd 228/238 113 +4 in my recent L92/402ci combo was lazy beyond belief down low, idled like crap with the reversion problems and didn't have enough manifold vacuum to brake well. Sure it went like a bat out of hell above 5K but I don't go there often except gettin' up on the freeway.
Old Dec 22, 2012 | 07:11 PM
  #103
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Really interested to see what kind of mileage you get out of this thing. Some of us still use our trucks as truks around here
Old Dec 22, 2012 | 07:14 PM
  #104
GMCtrk's Avatar
You've done a hell of a job with this build. Hats off for working outside the box.
I'm surprised to see you're still running vacuum assisted brakes.
Old Dec 22, 2012 | 07:24 PM
  #105
Duntov1967's Avatar
I swapped to hydroboost with this new motor. Huge difference!
Old Dec 22, 2012 | 07:53 PM
  #106
03sierraslt's Avatar
Well it should be a torque monster and fit what you are looking for, awesome work. How much boost do you plan to run?
Old Dec 24, 2012 | 01:30 AM
  #107
Camin00's Avatar
Yayyyyy for a tq fan over hp hahaha
Awesome build man. Dyno #s Dyno #s Dyno #s I have to know the tq difference haha
I have a 5.3L with the 210/218 .551/.551 on 116Lsa going in this week.
Truck put down 336 tq on 83lbs 20's If that cam could get me 360-370tq I would myself
Thanks for the info/time of sharing you build
Old Dec 24, 2012 | 06:26 PM
  #108
bennettracing's Avatar
Default Dyno #s
This is a great build I too am very interested in seeing the numbers my 6.0 in my sig has close to the same cam 403 tq 380 hp I'm thinking about boost myself
Old Jan 23, 2013 | 12:50 PM
  #109
Duntov1967's Avatar
Well heck. Had it on the dyno this morning but fuel pressure dropped to dangerous levels at boost creating a lean condition. It seems my Walbro 255 lph pump isn't enough to keep this thing fed with go juice. So now dual pumps are the next step. mad.gif
I wish Squash would release their pumps for sale.
Old Jan 23, 2013 | 07:45 PM
  #110
jjc839's Avatar
I am floored by your patience and persistance. Hats off.
