Stock 317 Valve Seals
Old Dec 10, 2017 | 02:20 PM
wretched73's Avatar
Default Stock 317 Valve Seals
I sent my stock 317 heads to be refreshed. I sent a set of BTR valve seals to the machinist and he said they were incorrect. Below is a pic of the stock seal he took out and the BTR ones. Can someone link me the correct seals?
TYIA
Old Dec 10, 2017 | 04:52 PM
Gadgetized's Avatar
What springs are you running?
Old Dec 10, 2017 | 05:03 PM
wretched73's Avatar
LS7 springs
Old Dec 11, 2017 | 10:55 AM
Drspencer's Avatar
5 Year Member
Rockauto.com
B45920 .88 cents a piece
B45921 .88 cents a piece
Shipping is $6
Don't forget about the 5% coupon code...
7236093164150674
Old Dec 12, 2017 | 11:14 AM
Prior to 01 the separate seat/seal was used on Gen 3 engines. In 01 GM went to the 1 piece seat/seal. The BTR seals will work provided you have a set of separate spring seats. You just can't use the 1 piece seat/seal with double springs as the inner spring will hit the seat/seal. I would not be using a machinist that doesn't know this or can't figure that out. It tells me they have no experience with Gen 3 heads.
Old Dec 16, 2017 | 11:04 PM
brandon6.0's Avatar
^^^exactly! The new seals go directly on the valve guide. The older one had the seals built onto the spring seats. Dual springs always come with the new seals u posted. U will need to get some stock replament seals from the parts store if u are running beehives.
Old Dec 17, 2017 | 01:23 PM
RPMSpeed Tech's Avatar
Truck Sponsor
You realize ls7 springs will handle MUCH LESS LIFT on a regular ls head right?
I hope you meant ls6.
Ls7 springs are made for a 1.960 installed height not 1.780.
Also tsps new dual spring kits come with a better 1 piece seat/seal for dual valve springs like stock, so you would have less issue tearing up seals or having issues. Just an FYI.
Yukon04
Dec 2, 2013 07:56 PM
BLOWN 364
Jul 29, 2012 01:33 PM
wzup1000
Jul 29, 2010 08:36 AM
99Silver6.0
Apr 23, 2005 11:11 AM
