Stock '08 5.3L heads?
Old Sep 17, 2008 | 06:06 PM
norris_83's Avatar
Default Stock '08 5.3L heads?
A little birdie once told me these heads were blueprinted from the 243 heads the Z06 had? Can anyone confirm if this is true? If so, I might hold up spending some extra cash to upgrade some fine flowing heads...
looking for a daily driver
Old Sep 17, 2008 | 06:17 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes they are 243, are great flowing heads, have a valve job, a mill, BAM
John
Old Dec 10, 2008 | 09:06 AM
norris_83's Avatar
my castings show 799... are these the same as the 243s??
Old Dec 10, 2008 | 11:13 AM
lsx10's Avatar
yes, 799 is the same as 243's
Old Dec 10, 2008 | 12:04 PM
Mark Johnson's Avatar
What heads do an LM7 have....................
Old Dec 10, 2008 | 12:16 PM
GMCtrk's Avatar
What size valves do those heads have?
Since those are the standard 4.8 and 5.3 heads, they should be available abundantly and cheap. I need some for my 6.0
Old Dec 10, 2008 | 12:33 PM
1.89". You'll need to enlarge'em to 2.0" for a 6.0 liter..............
Old Dec 10, 2008 | 01:19 PM
nighthawk08's Avatar
do the 4.8 and 5.3 GEN IV engines have the same valve sizes of the LS2? stock vs stock?
Old Dec 11, 2008 | 05:58 PM
lsx10's Avatar
as far as I know they are the same valves that are in the ls2's 243 heads, but dont quote me on it. they will not be all that abundant and cheap unless you can find someone who doesn't know what they have. as far as if your lm7 has them you'll have to look. the casting numbers are visable when installed. should be on the front right or left side. you will see either a 799 706 or 862
5.3lSilverado
25
Aug 29, 2016 12:48 AM
thunder550
Oct 8, 2015 04:53 PM
bobfig
Jul 25, 2015 04:42 PM
sauldgold
Jul 23, 2015 02:15 PM
4B11T
Jul 13, 2015 03:48 PM
