Still oozing oil???
Old Mar 6, 2015 | 10:57 PM
DrX's Avatar
DrX
Default Still oozing oil???
Haven't been under the truck in 4-5 months. I had wiped any oil off the back of the motor and oil pan 2-3 weeks after pulling the trans. Checked on it today and it is oozing oil just sitting there. There is a little oil on the lip of the bellhousing mating surface below there. There is oil all over the rear of the oil pan and on a knock sensor wire that is cable-tied to the head gasket at the rear of that cyl head. Where the heck is this oil coming from?
Attached Thumbnails Still oozing oil???-photo-2.jpg   Still oozing oil???-photo-3.jpg   Still oozing oil???-photo-6.jpg   Still oozing oil???-photo-7.jpg   Still oozing oil???-photo-1.jpg
Old Mar 6, 2015 | 11:27 PM
batboy's Avatar
11 Second Club
Maybe rear main seal?
Old Mar 7, 2015 | 05:12 AM
Gadgetized's Avatar
Mine does that and I can't stand it. If you still have the tranny off, reach in by the cam sensor and see if it is coming from there. You might even want to apply a light amount of compressed air to the crankcase to see if you can see it leaking. I'm interested in you findin out, I would love to fix mine too.
Old Mar 7, 2015 | 07:52 AM
DrX's Avatar
DrX
Rear main has been dry and it seems to come from above the bellhousing. No cam sensor back there(LSX block), but I have been suspicious of the valley cover, particularly since I had the the oil pressure sensor bung moved back on it to clear the intake. Still don't see where this much oil would come from just sitting. You can't see it well in the pics, but the rear of the pan is all yellow and there are drops of oil on the corners and rear pan bolts, with a puddle in the frame connector. The only reservoir of oil up top that I can think of would be what sits in the valvetrain area of the heads.
Old Mar 7, 2015 | 03:22 PM
DrX's Avatar
DrX
Found some oil sitting around the injector bosses on the intake on the drivers side. This side was always dry before. I guess now that I finally got the passenger side valve cover sealed up, it decided to start pushing out the other side. Will have to try the same as I ended up doing on the other side...run a bead of RTV around the inside of the gasket and let that cure before installing the valve cover.
Old May 23, 2016 | 09:01 PM
DrX's Avatar
DrX
Also wondering about possible seepage around the intake bolts. Noticed that those holes are drilled right through into the pockets in the heads where the oil pools and drains back into the crankcase. I am modifying some LS9/LSA intake gaskets to use with my setup and see that the seals extend around the bolt holes...not that those holes are any use to me with my ETP LS7 style heads. I had been using the Felpro paper gaskets. Probably didn't help that my intake bolts loosened up too.
Attached Thumbnails Still oozing oil???-lsa-ls9-intake-gasket.jpg   Still oozing oil???-felpro-ls7-gasket.jpg
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
