Stall Torque Converter Advice
I have a bagged 2003 Chevy Silverado it’s got a 5.3 214/222 .550/.550 lift 108 LSA chopacabra cam by Texas Speed. Long tube headers 1 3/4s, new valves springs.Is a 3000-3200 stall (4L60e) from Circle D a good combination with my current build? Appreciate your time
Because your engine will still make good power from even below 2500 probably, and you are just wasting it with too high of a stall speed converter. If you want a higher stall speed converter, you should get a higher RPM cam. Get it? Low RPM cam, low stall speed converter. High RPM cam, high stall speed converter.
And you have already been given the best possible advice, get the converter that Circle D suggests
