Springs and push rod with new cam ?
Old Jan 23, 2011 | 09:06 AM
Petey62782's Avatar
MASS seller approved
Default Springs and push rod with new cam ?
I'm going to do a XR265HR...212/218 .558/.563 115LSA cam and from what I've been reading new springs and rods are a must. I was also thinking of doing 1.8 rockers as well . My question is will the new rockers springs and rods fit under the stock covers and what recommendations for those three parts the springs, rods, and rockers?
Old Jan 23, 2011 | 09:08 AM
Petey62782's Avatar
BTW the engine is a LQ-9 with LT s , intake, TB and other mods with 2600 stall and 410 gears.
Old Jan 23, 2011 | 09:33 AM
lowslung85's Avatar
Id say some hardend 7.4 pushrods and some pac 1218 springs that are good to .600 lift and yes it will fit under the valve covers. And im not sure on the rockers i think since its a mild set up most people would say to stay with the factory rockers, imo
Old Jan 23, 2011 | 09:51 AM
blown 04's Avatar
I just did pushrods and pac 1218 springs in my v-max. got the whole kit from texas speed
as a package deal. if it were me i would just use your stock rockers and save the money for other mods.
Old Jan 23, 2011 | 10:45 AM
Petey62782's Avatar
Thanx for the advice
Old Jan 23, 2011 | 01:27 PM
jadaven's Avatar
Just installed that cam in my 4.8. I went with some hardened rods and a set of LS6 yellows I already had.
Old Jan 27, 2011 | 02:29 PM
Jon@Texas-Speed's Avatar
FormerVendor
I would go with a PAC 1218 spring or Comp 918 spring for sure. Throw them in with a set of chromoly pushrod and you should be good. Just about every OE replacement rocker will fit under the valve cover. Just make sure you have clearance before you run it and you will be fine. On some brands, they get really tight on clearance between the back side of the rocker and the inside edge of the head itself.
Jon
Old Jan 28, 2011 | 05:33 AM
03sierraslt's Avatar
Just do the cam, springs and pushrods. I wouldnt mess with the rockers.
Old Jan 28, 2011 | 08:17 PM
budhayes3's Avatar
PT's Slowest Truck
+1, I'd go with more cam for an LQ9 also
5.3Okasai
Mar 9, 2022 01:07 PM
Jake99
Aug 8, 2015 07:56 AM
bizle
Jul 22, 2015 07:31 PM
black6spdz
Jul 16, 2015 01:32 AM
NuckenFuts
Jul 9, 2015 08:45 AM
