specs?
Old Sep 1, 2007 | 10:46 PM
map0711's Avatar
Default specs?
was up guys, i'm halfway in putting the cam in my truck and i'm stuck. the cam is in the block, i just want to know if the small cover on the cam or anything else in the front of the engine had to be torqued down to certain specs. if so to what?
Old Sep 2, 2007 | 01:21 AM
map0711's Avatar
also i was thinking i should change my rocker arms, what do you guys recommend. 1.75 or 1.8
Old Sep 2, 2007 | 01:25 AM
ZZebes's Avatar
www.ls1howto.com and go to the F-Body Cam install
as for your rockers. Leave them alone, aftermarket cams dont like higher ratio rockers
Old Sep 2, 2007 | 01:35 AM
map0711's Avatar
its a stock ls6 cam
Old Sep 2, 2007 | 08:19 AM
OnyxSilveradoSS's Avatar
not too tight, they are o rings so you just have to snug them down. Loctite on what ever the directions say, high temp sealer on the cam cover.
Old Sep 4, 2007 | 01:14 AM
map0711's Avatar
thanks
Old Sep 4, 2007 | 10:41 AM
silver-mod-o's Avatar
Hunt&Fisherator
its a stock ls6 cam
even on the stock LS6 cam, I wouldnt go with aftermarket rockers.... not unless you had a custom cam built with a certain rocker ratio in mind...
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jscherbs
Sep 30, 2015 07:54 AM
okie454ss
Sep 22, 2015 07:39 AM
chvy=power
Sep 8, 2015 11:06 AM
