specs?
was up guys, i'm halfway in putting the cam in my truck and i'm stuck. the cam is in the block, i just want to know if the small cover on the cam or anything else in the front of the engine had to be torqued down to certain specs. if so to what?
as for your rockers. Leave them alone, aftermarket cams dont like higher ratio rockers
its a stock ls6 cam
even on the stock LS6 cam, I wouldnt go with aftermarket rockers.... not unless you had a custom cam built with a certain rocker ratio in mind...
jscherbs
Sep 30, 2015 07:54 AM
