school me on head swap (5.3)
Old Mar 14, 2010 | 10:41 AM
  #21
01SilvyZ71's Avatar
Originally Posted by RibeiroBJJ
For what you want a used Magnacharger Radix would do the trick...great towing,decent mpg, stock stall is fine and can be had for a little more than heads and stall....if not the same...something to think about...and guaranteed satisfaction
it was explained to me that the LSA was so low on the cam it wouldnt work could with FI something like 114 or higher would be better, is that true?
Old Mar 14, 2010 | 10:57 AM
  #22
RibeiroBJJ's Avatar
Praise The Lowered
For a daily driver you will be fine ...once again if you install a Radix with your cam and like the power and drivability ...than thats all that matters...Its better than forking over another 3-400 for a new cam thats "blower friendly" when your not drag/bracket racing...jmo
-But yes ideally 114 lsa or bigger is ideal...but imho not mandatory...
Old Mar 14, 2010 | 10:58 AM
  #23
01SilvyZ71's Avatar
ahh i seee
Old Mar 14, 2010 | 02:16 PM
  #24
AJII's Avatar
You need headers...I didn't feel ANY gains from my cam until I put the headers on it.
Old Mar 14, 2010 | 09:18 PM
  #25
Mark Johnson's Avatar
I'll hafta second that, l/t's B4 anyhing else..................
Old Mar 14, 2010 | 10:46 PM
  #26
PathfinderJr's Avatar
The reasoning is that tighter LSA's bleed off more cylinder pressure, ie less power in an FI application, due to the valves both being open together for longer periods of time.
Old Mar 14, 2010 | 11:11 PM
  #27
regcabls6's Avatar
port and mill the 5.3 heads. u can get them to flow about 300cfm with the right port program.
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 15, 2015 07:17 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
