SAD short story !!!
Old Dec 1, 2010 | 08:32 AM
slowec's Avatar
Default SAD short story !!!
20 psi oil pressure at idle this morning
I will update the thread when I get off and do some diagnostics
Old Dec 1, 2010 | 11:41 AM
slowec's Avatar
dtc p0327 knock sensor code found at lunch...
Oil pressure was perfect on very short trip to lunch. never got to full operating temp tho. over 60 psi @5k parking lot rev tho.
Old Dec 1, 2010 | 11:46 AM
MikeGyver's Avatar
Maybe a piece of crap had the relief valve stuck open. Good luck.
Old Dec 1, 2010 | 12:01 PM
mhotrodscooter's Avatar
Maybe gauge was acting crazy..
Old Dec 1, 2010 | 12:59 PM
matt29201's Avatar
what he said^^^^^^
Old Dec 1, 2010 | 01:16 PM
baSICK5.0's Avatar
Dang rodney. Not the time for this mess huh. You did just do the cam swap so maybe it was some junk.
Old Dec 1, 2010 | 01:26 PM
slowec's Avatar
I'll be at the shootout even if i have to drop a lil 5.3 in there for the time being.
Old Dec 1, 2010 | 01:30 PM
baSICK5.0's Avatar
things are tightening like hell for us right now. Ima try to squeek it out so I can still come.
btw on the note of Oil pressure. Mine is like 40 cold or hot at idle but going down the road at say 1700-2000 rpm it isnt but around 50 psi. Should i be scared? Maybe its just my oil thinning since i changed it. IDK. I noticed it but i cant really remember what it was previously. I thought higher though...maybe not
Old Dec 1, 2010 | 02:27 PM
00buckshot's Avatar
50 psi at that speed is real good to me! You better get that heap fixed Rodney! I'm comin for you!!!
Old Dec 1, 2010 | 06:19 PM
slowec's Avatar
I hope my willingness to share my stupidity will help someone!!! Turns out the oil was just thinned by a little water and assembly lube. Put some fresh 5-30 in there and she is holding 40 at a warm idle and it rises to 6X with more tp input. My knock sensors have went out though. i cut the filter and found no material so maybe I did not ruin anything.
