Rod/Main Bearing?
Old Dec 21, 2014 | 09:28 PM
Hivelocit's Avatar
Default Rod/Main Bearing?
I have a 2004 LQ4 I'm rebuilding and Summit has many different bearing sets and makes to choose from. Question is are all LS Engines Rod/Main Bearings cross compatible through the years from the 4.8-6.0? Only difference would be undersize or oversized correct? Thanks, can't find the answer anywhere!
Old Dec 21, 2014 | 11:29 PM
Hivelocit's Avatar
Anybody?
Old Dec 21, 2014 | 11:35 PM
Vortec350ss's Avatar
Are you literally just lookin for a stock replacement? Stock pistons and all?
Old Dec 21, 2014 | 11:52 PM
Hivelocit's Avatar
Well I'm buying some off here from someone and I was told all LS Rod/Main bearings are interchangeable for the LS engine. So I am just neding a confirmation on this being true? They will be stock undersized bearings as I had the crank turned.
Old Dec 22, 2014 | 08:42 AM
I'm sorry I think I misunderstood what you were lookin to do exactly... I thought you wanted rods and bearings. You only want the bearings. Yes as far as I know they are interchangeable
Old Dec 22, 2014 | 05:07 PM
dirt track racer 81's Avatar
All are interchangeable. The newer block do have different cam bearings.
Old Dec 22, 2014 | 05:29 PM
Hivelocit's Avatar
K Thanks guys! Good to know!
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
97_ek
Sep 23, 2015 09:16 PM
Velocity1
Sep 22, 2015 01:32 PM
600 horses
Sep 10, 2015 11:01 AM
