Rod Bolt SLEEVES
Old Sep 1, 2006 | 05:01 PM
dirt track racer 81's Avatar
Default Rod Bolt SLEEVES
Umm i cant get the bolt out of the cap because of this sleeve..is the sleeve supposed to come out..what do i do now??
Old Sep 1, 2006 | 05:04 PM
Zick's Avatar
They have to come out. You should be able to pull them out with the bolt.
Old Sep 2, 2006 | 10:25 PM
goshawk23's Avatar
Truck addict
place your channel locks on the bolt and just slightly wiggle the bolt till it comes out. make sure you screw the bolt out then back in about 4 or so threads so it holds when you pull it out. i did a write up on it
Old Sep 8, 2006 | 07:44 PM
SLED28's Avatar
FormerVendor
Put the cap in a vice (use alum or wood to clamp it so you dont score the side of the rod) then get a hammer and center punch and tap them out.
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
Jake75
Aug 5, 2015 01:26 PM
Ammadien
Jul 22, 2015 08:50 PM
