rocker arm question
Old Mar 10, 2006 | 07:52 PM
jus1975's Avatar
Default rocker arm question
I changed the cam and springs but when you change the rockeras do I use the guides that came with the rockers and how do you install them correctly . Do I still use the plate the mounted between the stock arms and heads
Just confused on what to use and how.
Old Mar 10, 2006 | 09:55 PM
TurboGibbs's Avatar
How about what kind of rockers do you have? That may help.
Old Mar 11, 2006 | 02:31 AM
jus1975's Avatar
rollers from Comp Cams.
Old Mar 11, 2006 | 07:54 PM
TurboGibbs's Avatar
I don't know for sure since I've never seen the kit but since no one else is piping in I'll add something. I don't think you reuse the factory lower alignment plate. Do some searches on LS1tech and LS1howto.com
Old Mar 11, 2006 | 09:36 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
No you do NOT use anything factor. You put the guide plates on with the studs through them into the factory rocker bosses and then put the rockers on the studs set valve lash and tighten down the poly locks.
The_W
Oct 28, 2015 09:00 PM
superchomper2003
Aug 26, 2015 09:39 AM
BigEd_72455
Aug 8, 2015 07:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
N/ALS1
11
Jul 13, 2015 10:56 PM
