replacing heads maybe...?
Old Feb 19, 2010 | 06:42 PM
mudaholicZ71's Avatar
Default replacing heads maybe...?
I pulled my driver side head to attempt a broken manifold bolt removal. which was obviously unsucessful i even brought it to a friend that owns a mechanic shop and he couldnt get it out i think he fucked it up even more honestly. so if i decided to go ahead and swap heads while i have the engine apart what would be my options? and what all would i need to run the different heads? I'd like to swap to a set of heads that would give me better performance but also allow me to use my stock cam for the time being until i can afford a different one. or if there is a set of heads that work well with the LS6 cam and springs (which i can generally find pretty cheap) i can afford that right now? also keep in mind my truck has 16" of lift 41" tires and 5.13 gears so I'm looking for torque as more so than HP
Old Feb 19, 2010 | 08:43 PM
DOA's Avatar
DOA
I think Stock 243s will yield you a little bump in performance. Should be able to find those pretty cheap. I'm pulling a set off my truck, but not for a few weeks.
Old Feb 19, 2010 | 08:51 PM
_zebra's Avatar
makes children cry
one thing you should consider is that the LS6 cam is more of a top-end performer
Old Feb 19, 2010 | 09:37 PM
acethedragon's Avatar
low duration, high lift of the 204/218 .550/.550 ls6 cam has proven a great upgrade for the trucks. especially in forced induction but n/a as well. its a great all around cam. i say go for the 243 heads with 02-04 ls6 cam
Old Feb 19, 2010 | 11:15 PM
Mrgoodwrench3's Avatar
I picked up a set of 706 heads for $40.00 last weekend. My plan is to port, polish and I am upgrading to Ferrea 2.00 intake valves. This should compliment the new cam well.
Dan Neumann
11
Aug 7, 2022 09:06 AM
Denali08
Aug 9, 2015 04:34 PM
sauldgold
Jul 23, 2015 02:15 PM
